Upgrading Data Question
bigmama413
Hi All
Just wondering, if i upgrade my data (not just an add on) for my monthly plan will it take effect right away or the next renewal date? Thanks
Strangetam3r
If you cancel your plan early, before it renews and buy the upgraded option you'll just have to pay twice
JL9
How close are you to your renewal? If you can wait it would be more cost effective to change at next renewal, if you still have a ton of time to go and absolutely need it, you can change immediately
@bigmama413   You can choose between Change Now or Change in the next renewal date.
With Change now, PM will charge you new plan amount now and starts the new cycle.  All the unused days on the current cycle will be forfeited
E-MyAcct-ChangePlanNow-NextCycle
MrSpock
@bigmama413 you have a choice if you do it now you will lose credits for the rest of this cycle you already paid for or you can plan it for next renewal date
