Upgrade subscription
Chindyno
I'm considering upgrading the existing plan to the $40 for 60 GB plan under the Boxing Week special.
What happens if I were to downgrade back to the existing $25/month 1gb plan in the future. Will I be reverted back to my current plan ? Also will I be able to keep all my bonuses?
2 REPLIES 2
Dunkman
@Chindyno
You are welcome to change plans as often as you like.  You keep your rewards.
However, if your existing plan is not available anymore (ie. grandfathered), you will not be able to switch back.  You are only able to change plans to whatever is available at the present moment.
@Chindyno
Yes, this is the good thing about PM. You can switch plans whenever you want and the Rewards will stay with whatever plan you go with.
But remember to switch plan on your next renewal date.
I think the Boxing Day promo have expired but you can check to see if it is available on your account.
