08-24-2020 05:02 PM - edited 01-05-2022 03:39 PM
I updated my plan and as of yesterday I should have had 5Gb of data available to me. I have no data working at all right now. What do I need to do? Please!
08-25-2020 12:14 AM - edited 08-25-2020 12:15 AM
Go to settings...connections.....mobile networks...
Edit: your 5mb buffer has been taken....looks good.
08-25-2020 12:05 AM
Data limit is 5120 .... data available is 5114.556 .... I think it may have just started working....
08-24-2020 11:57 PM - edited 08-24-2020 11:59 PM
@phadikin wrote:The phone has been powered off ... sim removed ... put back and restarted. Is that ok?
Maybe restart without the SIM in. Then off again and re-insert the SIM and restart.
What make/model/submodel is the phone? What OS is it running?
08-24-2020 11:53 PM
How do I find them?
08-24-2020 11:53 PM
@phadikin SIM works or doesn't. Taking it out and putting back in won't fix data.
08-24-2020 11:52 PM - edited 08-24-2020 11:56 PM
Have you checked your network settings? You might need to reset them. What do they say?
Edit: Do you have any access to data...wifi? Can you send MMS?
08-24-2020 11:48 PM
08-24-2020 11:46 PM
@phadikin wrote:How do I open a ticket ... it is still not working after the lost/stolen and the $1 payment. Thank you.
The earlier reply from computergeek541 is where to go to get started.
Have you also restarted the phone?
08-24-2020 11:40 PM
08-24-2020 05:23 PM
@computergeek541 wrote:
@phadikin wrote:I updated my plan and as of yesterday I should have had 5Gb of data available to me. I have no data working at all right now. What do I need to do? Please!
Assuming that data was working before, it sounds as if the plan change did something to the provisioning of your data services. I believe you're going to to have to get a moderator to fix this. You can open a ticket by going to: https://publicmobile.ca.ada.support/chat
Are we stop recommending the lost/stolen phone or $1 tricks?
In the past, lost/stolen has caused problems with rewards.
Agree. Now, I only ask subscribers to try the $1 trick only. If no avail, then support ticket.
08-24-2020 05:11 PM
08-24-2020 05:08 PM
08-24-2020 05:06 PM
@phadikin You can try Fly mode or lost/stolen feature via self-service account for several mins to trigger the system.
08-24-2020 05:06 PM
08-24-2020 05:05 PM
Log into your account. Under My data and add-ons does it show you have data available?.
Has your data every worked?
What kind of phone do you have?
08-24-2020 05:05 PM - edited 08-24-2020 05:06 PM
@phadikinDid you try restarting your phone
Please logon your account to be sure the plan change worked and that your account is active.
