Updated Visa card
RobV1
I've updated my Visa card to my account and I thought it was also tied into my wife's account  but she's lost her phone service for non-payment. I don't know where to find her account. I think we shared my email but it will only open my account.
ottawa
Also note that each account at PM is 1 phone line and 1 email. Assuming your wife has her own email address(es), you could try those. Assuming you don't remember the password on PM (you could try your password first, in case you used the same for both), there's a "forgot my password" type link too. Not sure how far you can get without being able to receive a text on her line, but might be worth a try while you wait for the agents.
RobV1
Thanks
mitchnet12
Wow too much info. This is a public web forum. Edit your post to remove your personal info. Try opening a ticket with Simon here.
Hi @RobV1 pls remove the number for your safety,  you are posting in a public forum.
You need the login for your wife account.  Please open ticket with CS agent
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
