11-29-2022
10:01 AM
11-29-2022
10:20 AM
computergeek541
I updated my phone last night. Everything worked fine before the update. I have tried resetting my network settings, factory resetting my phone, and rolling back to an older firmware and nothing has fixed the issue. Does anyone have any suggestions because I am stumped.
Thanks
05:27 PM
12-09-2022
04:32 PM
Luddite
Update: I have finally fixed it. I had to downgrade my phone's firmware twice......
Last Oneplus phone for me. Thanks for the help gang
[✔️ .......Luddite]
11-29-2022 03:44 PM
I just did a manual search and Public Mobile is not on the list! Rogers, Bell, Telus etc all show up.
Public mobile was working fine before the update....
11-29-2022 10:20 AM
11-29-2022 10:19 AM
@JK8 wrote:
Check your apn settings:
https://apn-canada.gishan.net/en
APN only affects data and MMS. Network connectivity has nothing to do with APN setting even if it was incorrectly set.
11-29-2022 10:19 AM
@shawno11 , please try doing a manual network search, see if Public Mobile shows up on the list.
11-29-2022 10:08 AM - edited 11-29-2022 11:02 AM
