Company phone number not coming through
antonius123
Hi,
My hearing aid clinic tried to call me numerous times, but their phone number doesn't get through to my cellphone. I see no missed calls or anything, and all they hear is a weird beeping noise instead of reaching my phone. I looked through all my phone calls, and I don't think I ever blocked them. Is there an auto-block from Public Mobile??
Thanks!
8 REPLIES 8
antonius123
only this clinic, never had a problem and my brother called me today
Metal1967
@antonius123  Sounds like they called  a fax number…only weird beeping these days…
ottawa
Also check if anyone else has called but didn't get through (if the company shows up in your Usage History, look for others). That will help tell you if it's unique to them, or a problem on your end.
JK8
@antonius123
If you log into self service do you see a record of them calling you in Usage History? Maybe ask them to dial your number with a 1 in front. Add their number to your contacts.
@antonius123    Try adding their phone number in your contacts list, manually in your phone.
antonius123
Yes I'm sure my plan is active as I called them today with my cellphone. Also, my phone is not on do not disturb.
Yummy
No auto-block from PM.
It could be you have set in your phone to reject all 'unknown' callers. Some medical institution do not provide phone numbers and their calls show up as unknown. Very annoying from their side like they are hiding from somebody. Have experience witch such calls...
IF only that company has issues reaching you then it is something weird set up on their side.
walker1
@antonius123   PM doesn't have any auto block for calling.  Are you sure that your plan and account is active still?
Try restarting your phone and see if that helps.
Make sure you don't have the do not disturb feature turned on in your phone.
