12-27-2021 07:31 AM - edited 01-04-2022 04:47 AM
Hi,
My credit card expired and I have a new one. How do I update my AutoPay?
Thank you.
Warren Martin
My Account
12-27-2021 12:25 PM
12-27-2021 08:57 AM - edited 12-27-2021 09:00 AM
Here is information about clearing cache in Chrome.
https://www.wikihow.com/Clear-the-Cache-in-Chrome
Here is more information about clearing cache and cookies in different browsers.
12-27-2021 07:46 AM
Depending on the device you're using, by navigating to your search history of web pages, there you'll find options to clear browsing history and such.
12-27-2021 07:46 AM - edited 12-27-2021 07:47 AM
@wmartin2167 wrote:How do I clear browser’s caches and update cookies?
Thanks.
Warren Martin
@wmartin2167 - it depends what type of device you are on, I suppose. Start by looking under your HISTORY, then SHOW FULL HISTORY, then you should see something showing 'Clear cache data and/or cookies.
EDIT - but you do not need to do this unless you are receiving error when you log into your SELF SERVE account or it is missing content.
12-27-2021 07:44 AM
Thanks.
Warren Martin
12-27-2021 07:41 AM
Hello @wmartin2167
Before logging into your self-serve account to begin, recommend following this procedure to avoid the common glitches that sometimes occur with this process:
- Clear your browser's cache & cookies
- Use incognito mode
- Now, log into your self-serve account
- Click Payment tab
- Select "Manage My Card"
- Select "replace card"
- Type your address exactly as from your billing statement
- Don't use a space in the postal code
- Use ALL CAPS if necessary
- Type everything, not letting autofill complete any fields
12-27-2021 07:35 AM
@wmartin2167 wrote:Hi,
Thank you.
Warren Martin
Log into Self Serve account, if you have not created one yet, you can do that here: https://selfserve.publicmobile.ca/self-registration/
Then navigate to the PAYMENT Tab and go to the bottom, left corner of the page to update your card.
12-27-2021 07:34 AM
