02-25-2022 09:49 AM
Hi,
I have been charged for this merchant from the credit card on monthly basis. But I don't have any account with this community for anything.
Please look into this asap
02-26-2022 12:21 AM - edited 02-26-2022 12:23 AM
@Sheeba wrote:I have been charged for this merchant from the credit card on monthly basis. But I don't have any account with this community for anything.
This being the case, I don't see there being any reason for you to contact Public Mobile as you're not even a customer. As mentioned by others, you do need to immediately contact your credit card issuer, except I'm going to say to take a it a step further. Tell your credit card issuer/bank that you do not have a business relationship with Pubilc mobile and that this is an unauthorized charge. You having no prior relationship with the company (Public Mobile) very likely means that your credit card issuer will immediately perform a chargeback and also immediately refund the charge.
02-25-2022 12:47 PM
If you are no longer a PM customer, I suggest you call your CC and tell them that you suspect that your CC was compromised or it could be a mistake but should investigate.
02-25-2022 11:40 AM
Merchant detail number is correct.
Do you have ANY mobile service from Telus family providers? Sometimes you might see different 'sibling' name instead of what you subscribe with.
As this goes on monthly basis, why you did not complain earlier? Amount could correspond to $70 plan with $2 off for autopay. Exactly $68+13%=76.84.
Your credit card might be compromised or somebody from your family subscribed to PM using your card.
You can ask agent if they could find which customer has your card on file and determine who is using it for PM service.
You can talk to your bank declaring you do not recognize this transaction(s) and ask them to investigate.
02-25-2022 10:00 AM
HI @Sheeba do you ever have any service with Public Mobile/Koodo/Telus? or any chance someone in your family using your credit card?
I believe you don't have an Active account with Public Mobile, so for your issue, you will have to open ticket with PM support via direct message here:
After ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent (You have to check the Community inbox, they don't reply via regular email)
02-25-2022 09:53 AM - edited 02-25-2022 09:53 AM
If you're certain this doesn't represent payment for services you hold with Public Mobile:
02-25-2022 09:52 AM
@Sheeba Public Mobile is a cell provider owned by Telus. So you're saying that you do not use Public Mobile as your cell provider?
You'll need to contact support for them to investigate.
Contact customer service agents.
Open a ticket via:
https://widget.telus.tiia.ai/publicmobile/publicmobile.html (faster response time)
Type "ticket" > Click "Contact Us" > Select your issue > "Click here to submit a ticket↗"
or send a private message to:
and describe your issue. Include your name,phone #, account #, Email address,4-digit PIN to speed up authentication process.
