Unlimited data?
Hatchfen
how do you see what the note is at the end of sentence 1
7 REPLIES 7
Sign into your accounts and check to see if you have this offer.
If you are interested,  select Change on Renewal.
Sansan
Scroll to the bottom of the page a d click the plus ️ Terms and conditions.
All the info is there.
hi @Hatchfen
the note at the end of sentence 1 is :
11 To access 5G network speeds, ensure you have a compatible phone, your phone’s software is up-to-date and you are connected to the Public Mobile 5G network where available. Speed and signal strength may vary with your device, configuration, Internet traffic, environmental conditions, applicable network management policies and other factors. For more information about our coverage, please refer here.
SKSuh
An unlimited plan is currently
available for me to select
Socrates8567
If this is for a new account you're looking at getting, click on Shop at the top. Pick a plan, I'll use the $40 plan as my example here. Click on Subscribe now, next page under the blue Subscribe Now banner, you'll see Terms and Service. Click on that and you will see what the numbers mean after things.
Hope that helps.
hairbag1
@Hatchfen
no unlimited plans currently or even offered recently.
slusagm
@Hatchfen
unless you have unlimited 5G plan already, it is no longer important  as there is no more unlimited 5G plan at the moment
