Unlimited Canada-wide Talk
LizSaam
I'm visiting Ontario next week from BC. Does "Unlimited Canada-wide Talk" mean I can call from anywhere within Canada to anywhere else within Canada without extra fees? Is texting? Please advise.
dabr
@forfun    Are you on an older legacy plan with provincial calling only?  If so and you want to make/receive calls, it might be easier to just purchase the $5/500 Canada wide minutes which are non expiring so any remaining minutes will stay with your account until depleted unlike the new 30 day policy for add-on data.
Or it might be a good idea to take a look at PM's current plans as they all include Canada wide calling and some offer lots of data at 4G or 5G speeds as well.
forfun
would that mean I can call from BC to PEI while my home province is ON while I'm travelling in BC?
wetcoaster
Adding to the above:
There will also never be any extra fees, after the fact, at Public Mobile: If you don't pay for a feature up-front (in your plan or as an add-on) you can't use it.
dust2dust
All services work the same way all across Canada. If you have an old province-wide plan then there are some differences.
