02-09-2020 06:03 PM - edited 01-05-2022 09:25 AM
Hey I'm interested in purchasing a Titan for my next phone and wanted to make sure it could work with public mobile before I think about pulling the trigger
https://www.unihertz.com/shop/product/titan-pre-order-39
if anyone could point me in the right direction I would appreciate it.
Phones
02-10-2020 02:30 PM
According to the link you provided, it should work. Just to be sure, you could take it to a mobile retailer and have them check to see if it is compatible.
02-10-2020 02:11 PM
@Opekaset Go for it!!, It will work as previously mentioned.
02-09-2020 06:32 PM
@Opekaset wrote:Hey I'm interested in purchasing a Titan for my next phone and wanted to make sure it could work with public mobile before I think about pulling the trigger
Telus supports
3G: B2 and B5
LTE: B2, B4, B5, B7, B12, B13, B17 and B29
According to your link, this phone supports the following bands. If its info is correct, it should work with PM.
WCDMA: Band1/2/4/5/6/8/19
FDD/TDD LTE:
Band 1/2/3/4/5/7/8/12/13/17/18/19/20/25/26/28A/
28B/34/38/39/40/41/66
02-09-2020 06:27 PM - edited 02-09-2020 06:27 PM
@Triguy wrote:The phone bears an uncanny resemblance to a Blackberry.
Yeah, that was the 1st thing I noticed about it, followed immediately by the sheer, massive capacity of that battery! 😮
02-09-2020 06:24 PM - edited 02-09-2020 06:32 PM
@Opekaset Have just looked at the specs for that phone, via the link you provided, and it APPEARS to me that it would work, but I'd wait 'til someone else, with a little more knowledge on the topic, weighs in on this topic.
Aaaaand @Triguy ninjas me, with the info I had already looked for, but couldn't find, cuz my search skillz need an upgrade. 😉
Edit - as it turns out, I had saved a link to a post that had the required info laid out in a simpler fashion, listing just the bands necessary for PM: https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Samsung-Galaxy-M30s-A30s-compatibilit...
02-09-2020 06:23 PM
Here is a previous thread with more info.
