Unauthorized Calls
Prdrader
Since I have signed up I have seen 2 outgoing calls to the same number that I never made both lasting 5 seconds. Has anyone else had this issue?
Prdrader
Thank you. It does end in 4001. Apparently I received calls while my phone was in DND.
Chalupa_Batman
Hello @Prdrader
Take a look at this list and see if you find the number. To me, this sounds like a voicemail call out. Meaning someone dialed you, got your voicemail and was redirected there.
https://productioncommunity.publicmobile.ca/t5/Get-Support/Updated-list-of-Voicemail-Access-Numbers/...
I see my provincial number on this list show up all the time as I let most people go to my voicemail.
hi @Prdrader
this is the list of the voicemail number, if the numbers in question are here, you are safe
slusagm
do they end with 4001? that's voicemail. The usage history keeps a record of calls going to Voicemail, too., like when someone left a VM or when you check VM yourself
Sansan
@Prdrader  could be your voicemail. When you check voicemail it usually ends with 4001, 4002
