03-08-2019 11:08 AM - edited 01-05-2022 06:48 AM
I am trying to renew my plan and I keep on getting an unable to verify card information error...
I have called my credit card company and all my information is correct
Is there a mod that could help?
03-14-2019 05:02 PM
try another time, the PM always fail on their website
03-13-2019 08:53 PM
normal time for simple answer mabe you can try to use a scotch tape cut it the size of your card and try to put it back your phone if that work it mean you card reader is damaged if not its because your sim card is broken
03-08-2019 11:15 AM
Double-check the expiry date on your card.
03-08-2019 11:13 AM
To reach the moderator here...https://productioncommunity.publicmobile.ca/t5/notes/composepage. and write moderator_team in send to.
Waiting time is few hours to 2days.
For your problem with your card you can try a different browser or an incognito mode. Clear your cache for each try.
03-08-2019 11:11 AM
@DaniF wrote:I am trying to renew my plan and I keep on getting an unable to verify card information error...
If you've tried many times then it might be locked out due to thinking of fraud.
Otherwise, make sure the name and address exactly match that of your credit card billing name and address. Don't use the unit # field. No space in the postal code.
You can also use vouchers to pay. Get them from a store or online at recharge.com.
