06-23-2023 12:34 PM
Public Mobile confirmed that she was accepted. They even sent referral code. However her phone is still not working
06-23-2023 12:50 PM
Did you read the recommendations on your other post?
She should reboot her phone by powering it off then back on.
If that didn’t work then it could be a provisional/backend issue with the SIM.
If this is the case, she needs create a Eversafe ID and to contact a CS_Agent directly by private messaging on the computer or tap on her avatar then to Messages.
06-23-2023 12:47 PM
@Brenda14 just activated?
Try Reboot your phone as well as try to click Reset All Networks
If that does not work, still show the sim not connected to the network, no worry, it is just sim card provisioning issue. Easy fix for PM, you will just need to open ticket with them here:
06-23-2023 12:36 PM
@Brenda14 Have you tried rebooting the phone with PM SIM card in it . Do you have any services like call text or data
