Unable to use data
vidishar
Recently transferred from other mobile carrier to public mobile. Account, payment, plan everything is done. Getting full signals but unable to use data. I am using android device.
Kstar1
Do a hard reset
HI @vidishar
Check the APN settings
https://www.publicmobile.ca/en/bc/get-help/articles/set-up-data-on-an-android-phone
if it is an LG, you certainly need to Reset All Network
dust2dust
Check the APN settings. Of course the obvious turn on the data.
@vidishar   what kind of phone is that? brand and model?
First try to "Reset all network" and see if it helps
Also, you might want to try the PM sim card in another phone
Another phone to check is to check the APN settings, maybe you can follow this and update it accordingly
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include dun for hotspot)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
LoveNature
@vidishar
reset network, and reboot device.
