Unable to use data
nazia
I have paid to active my plan last week but still I am unable to use data. I can use talktime but not mobile data.
12 REPLIES 12
@nazia wrote:
@srlawren I have used all of my data before my next renewal date. My next renewal date is June 28.Does it mean I have to wait till 28 to use data?
Yes. This is a prepay service. You don't prepay for overages. The service just stops. You can add data add-ons onto your account to hold you over until the 28th. Or you could go through the mods and do an early renewal. Or you could do an immediate plan change which would lose what you've paid for until the 28th.
Edit: ninja'd by jimmorrison 🙂
mojorising
Yes. unless you buy additonal data add-on to hold you over.
nazia
srlawren
@mojorising wrote:
@nazia wrote:
500 MB.$30 per 30days
Ok. When you go into your "My Account", in the "My Data & Add-Ons" area how much data used does it show?
@nazia it looks like you've marked this reply from @mojorising as the solution. Is your problem solved? It doesn't sound like it from subsequent replies, so I'm confused.
It you still can't use your data:  when exactly did it stop?  Did it stop before your last renewal date?  Did it stop on your last renewal date?  Or did it stop after?  If your usage on the Overview page of your account shows you've only used 1MB you should have plenty left, so that's not the issue.
Have you checked your phone settings to make sure you didn't accidentally disable your mobile data?  On at least some phones, it's a quick-toggle in the settings menu you pull down from the top, and it's easy to accidentally toggle it without noticing (I'm speaking from personal experience here!).  Also: have you rebooted your phone recently?  If it's been some time, it's definitely worth trying.
nazia
1MB
Psygineer
That plan doesn't exist anymore, you should switch to the $25 plan for your next renewal. It gives the same options as that one for $5 less.
mojorising
Psygineer
@nazia wrote:
Yes.I used it before.
So it worked previously and now it suddenly stopped? Did you disable mobile data in your settings? Have you used up all your data already (Streaming videos will kill it fast). There is no overage so if you ran out, you would have nothing left until your next renewal.
Or do you mean it worked on your previous carrier, if so, you still need to adjust the APN for PM.
nazia
Psygineer
Is your APN set up correctly?
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Leave blank
APN type: Leave blank
nazia
mojorising
What plan do you have?
