08-31-2021 03:04 PM - edited 01-06-2022 03:19 AM
I transferred my number from Freedom last month successfully but got a message from Public stating that transfer did not complete and I was assigned a new number. How do I get my old number back?
08-31-2021 05:58 PM
@computergeek541 wrote:@Anonymous @darlicious
By the time that Public Mobile gives out a number phone number after porting failure, the original transfer request has already been closed. A CSA can no longer fix the porting request, nor will responding to the porting authorization text message allow the port to be completed. A new number porting request has to be started by the customer in Self Serve.
The "successful" message show on the computer screen does not mean that the phone number transfer worked. It's bad choice of wording by Public Mobile and only means that they received the request.
Ya think? Please note in my reply:
Do you still have your freedom SIM card? If so put it back in your phone so you can reply YES to the PAT(porting authorization text) within 90 minutes of receiving it. If you do not have the SIM card call freedom to verbally authorize the port request after you have made the port request in your self serve account.
08-31-2021 05:14 PM - edited 08-31-2021 05:33 PM
but that person why is will losing number, if then call to Freedom, and maybe the Freedom agent can't help with it, i don't know how many days is allowed to do it , but if them pay to PM and is the service is working with PM then CSA is responsible to getting Own the number from Freedom and i think that person need a account number for Freedom to give to CSA make a file complaint with Freedom to get then back that number,
or that person if you like to gettign a new number from PM, and is will fix it that issue....
08-31-2021 05:01 PM
Softech,
Yes, I tapped on the wrong username.
08-31-2021 04:38 PM
@computergeek541 .. yes.. I asked OP to re request porting on My Account.. I think you tagged wrong person
08-31-2021 04:32 PM - edited 08-31-2021 05:00 PM
08-31-2021 04:30 PM
Check to see if your Freedom account is still active. Try to request the port again and put your Freedom sim back into your phone.
https://www.publicmobile.ca/en/on/get-help/articles/number-transfer-port-troubleshooting
08-31-2021 04:18 PM
@mwm0647 did you login to your Freedom account and confirm it is active? Likely you still paying for your Freedom account at this moment
If you still have your Freedom SIM, put your Freedom SIM in a phone and confirm you can make outgoing calls and receive incoming Keep the Freedom SIM there
Then logon to PM My Account, click in Change Phone Number and request porting there (You will need to enter your Freedom account number).
Once requested, you should receive a text on your Freedom SIM to ask for your permission to port the number. You need to reply YES within 90 min.
once you replied Yes, the port should complete within an hour or two and your Freedom account should be closed.
let us know how it goes.
08-31-2021 03:41 PM
08-31-2021 03:12 PM
Explain your issue to Contact Customer Support Agent by CS_Agent ,
they can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent, and Submit a Ticket
Good Luck....
08-31-2021 03:09 PM - edited 08-31-2021 07:28 PM
@mwm0647 wrote:I transferred my number from Freedom last month successfully but got a message from Public stating that transfer did not complete and I was assigned a new number. How do I get my old number back?
This happened because the portinh request was rejected by Freedom Mobile. You'll need to to go into your Public Mobile self aerve account to make another request. You'll want to make sure that your Freedom service is still working and that you have the Freedom account number.
