4 weeks ago
- last edited
4 weeks ago
I’m having the exact same problem I don’t have a solution just letting you know you are not alone !!
4 weeks ago
@ alic761
An agent is already reviewing your ticket. Please check your Community account inbox and respond as soon as possible.
4 weeks ago
I have tried resetting the phone tried checking to see if it’s there on the phone it isn’t. I never got an email confirming the email and with the QR code. I keep getting an error message in the app saying we’re sorry something went wrong please try again. When signing into the app I can still access everything etc but the message keeps popping up I’ve tried reinstalling the app I’m about out of ideas
4 weeks ago
Reboot your phone and try login PM app again and see if it can completed
Even if you are getting the same error, check if the SIM was already installed. Sometimes the error is because the sim was there but not properly setup.
On Android: Check your Sim Card Manager and see if a Public Mobile eSim is there. If so, make sure it is enabled.
On iPhone: check Settings > Celluar and see if the eSIM is there. If it is, make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on
if you don't see the Public Mobile esim there, check the Welcome email, there should be a QR code for the esim for you to scan and install manually. If you cannot find it in Inbox of your email, check also the Spam box.
If the Public Mobile eSIM is there, disable or delete those non PM sim (eSIM/Physical sim).
If the non-PM sim is physical, remove it. If the non-PM sim is an esim, disable using the SIM Manager on the phone (or set as Secondary and turn off "Turn on this line" for this non-PM esim)
Then reboot the phone and click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
4 weeks ago
I purchased an eSIM but it did not go through to the install process all I got was a message saying were unable to perform at this time’ or along those lines my account shows that the eSIM was purchased but I didn’t receive an email confirming or with the QR code still haven’t heard back from CS_agent
4 weeks ago
what is your issue? Kindly share and we will see if we can assist
At the same time, I have escalated your ticket on your behalf. PM support will reach out to your via Community inbox. Please monitor here for their reply:
4 weeks ago
I did try that I haven’t heard anything back yet thank you for the help
4 weeks ago
If you cannot login My Account and unable to submit a ticket using Chatbot, please engage PM CS agent by direct message using this link:
