Unable to sign-in since outage started.
Heikki
I am unable to sign in to my account ever since outage started 2 days ago. Tried Incognito, cleared cache and cookies, tried different browsers, nothing seems to work. Every time I try to sign in I get the message "Page Expired". Only upside is my phone still works. Not impressed.
10 REPLIES 10
Heikki
Update: PM wouldn't even let me open a ticket. Long story, just gave up. Decided to just wait a few days to see if things correct. I can now sign in BUT if I sign in using regular browser tab I get Account Status: Active but details are my old plan (I upgraded plan at renewal which was during outage). If I sign in using Private tab or Incognito then I get Account Status: Active and the details are my new, upgraded plan. Been like this for a few days so not sure if it will correct down the road; maybe on next renewal. Weird stuff.
Heikki
Thanks, but been there done that; no go. Tried 4 different browsers on different units (cell phone, laptop and desktop) not happening. Have to wait and see.
Community_QA
@Heikki  I see Page Expired sometimes.  Usually close and relaunch browser work for me.  But keep 3 different browsers around and try them 1 by 1
CountyDownIeUk
Try a different browser.
I have noticed this today.
o I can log into My Account
o I cannot log into My Account  as part of the verification process when submitting  a ticket.
PM website is definitely broken.
Heikki
Support ticket seems to be only way to go. Thanks.
popping
Keep us updated what went wrong with your account.
Heikki
Thanks for quick response. Unfortunately, refresh and going to link without using bookmark get same result. Have to try to open ticket, and hope for better luck than I had previously using Chatbot. Thanks again.
popping
I use Firefox on my Windows 10 laptop.
I  go to community forum first, exit and login to my account the first time may get a blank login page.  I reenter my username and password again.  it usually work.
If you failed to login many time, PM server may lock your account for an hour.  Try again after 1 hour.  If fails again, creat a support ticket to get CA Agent help.
Hi @Heikki if you press back , then refresh,  it is same?
if you have the site  bookmarked,  don't use that.  Use the link https://selfserve.publicmobile.ca
in case it still does not work,  open ticket with CS agent
at : https://publicmobile.ca/chatbot.
First type Forgot login,
CountyDownIeUk
Try to refresh the browser screen.
