05-26-2019 10:32 PM - edited 01-05-2022 05:06 AM
Hi, I just activated a new PM plan and got a new number along with it. I can make and receive phone calls, and data is working just fine too. I was about to go ahead to make a new account, but never receive the text containing the 6-digit code. I tried sending out texts and asking others to send me texts, and nothing seem to happen. I have a samsung S4 phone. Any suggestion on how to resolve the issue? Thank you.
06-03-2019 10:00 AM
@Fina wrote:Yes, and it took PM 5 days to fix the problem because they could not understand why or what caused it.
Fina
I know what you mean....
06-03-2019 09:56 AM
Fina
06-03-2019 09:52 AM
@Fina good news!
06-03-2019 09:51 AM
Thank you everyone for all the suggestions. I did contact a moderator, and it took the moderator several tries before it is fixed. Apparently there was a glitch in the system that prevented me to send or receive sms. The moderator sent the problem to the tech support, and the problem was solved. It works like a charm now. Thank you all and I thank the PM moderators for helping and doing their best.
Fina
05-27-2019 12:25 AM
Hi, can you send a MMS (picture text)?
For SMS (normal texting), verify the SMSC (short message service center) setting is +16475800172
05-27-2019 12:04 AM
@Fina wrote:Hi, I just activated a new PM plan and got a new number along with it. I can make and receive phone calls, and data is working just fine too. I was about to go ahead to make a new account, but never receive the text containing the 6-digit code. I tried sending out texts and asking others to send me texts, and nothing seem to happen. I have a samsung S4 phone. Any suggestion on how to resolve the issue? Thank you.
@Fina What plan are you on?
05-26-2019 10:49 PM
Can you try your PM SIM card in another phone to determine whether it is a hardware issue versus PM service issue?
If it is a PM service issue, then you will need to contact moderator to help you.
Send a private message to moderator through the following link :
If it is a phone issue, you could try network reset or even factory reset.
