12-03-2021 04:22 PM - edited 01-06-2022 04:05 AM
12-04-2021 09:08 AM
12-03-2021 05:24 PM
@CindyMacRae wrote:I did everything you suggested but that did not work. Still unable to receive calls
did you call the porting team? I sent you a message. for the number. Check the Community inbox, envelop icon on the top right.
Not sure if you have called yet. If so, what did they say in terms of porting status?
12-03-2021 05:22 PM
12-03-2021 04:35 PM
@CindyMacRae wrote:I am not sure what you mean by port.
Port / Porting -- transfer your phone number
Look like you did request to transfer your old number to PM and I think it wasn't completed successfully
Check the Community inbox, I sent you a number to contact PM to confirm the phone number transfer status
12-03-2021 04:33 PM
mabye you stuck with Transferring your old Phone Number,is not complete,
you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
them can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,
Good Luck..
12-03-2021 04:33 PM
I am not sure what you mean by port. I answered yes when my previous service askes and autoerized it with a YES
12-03-2021 04:31 PM
Can you confirm that your account is closed with your old provider?
Can you try your sim in another unlocked phone?
12-03-2021 04:31 PM - edited 12-03-2021 04:32 PM
@CindyMacRae wrote:I did rely yes to last provider
@CindyMacRae did you reply YES within 90 mins?
put your old SIM back to a phone and see if you can make calls or receive calls on your old provider. If you can , then porting is not completed
Also, I will message you a phone number you can call to get the porting status. Please check your Community inbox, envelop icon on top right
12-03-2021 04:29 PM
@CindyMacRae wrote:I am new to Public, since Monday,
Did you port a number over?
12-03-2021 04:29 PM
12-03-2021 04:29 PM
12-03-2021 04:26 PM
Are you a new customer? Did you port a number over? If yes, it will take a couple of hours to complete the port? Can you receive a txt?
12-03-2021 04:25 PM
@CindyMacRae outgoing calls working no issue?
data working?
just incoming call and text?
Did you just port your number over to PM? If so, if you reply YES to your previous provider to approve the number porting?
If you are not new to PM or didn't request porting ,maybe you can provide us more information?
12-03-2021 04:22 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
