08-20-2019 10:20 AM - edited 01-05-2022 06:30 AM
I am unable to receive calls but i can make calls can anyone please help me i just moved to pm yesterday. Thank u
08-20-2019 11:27 AM
@Maninderminhas It is normal during a port that you can make calls and texts but can't receive calls and texts because those go to the Sim card with the provider you are leaving. Who are you porting from? Which company? If it's from another cellular company it should happen within 24 hours, except certain ones like Koodo you need moderator assistance. If you are porting from a home phone line or voip, it takes longer, and can take a few days up to 7 days. You will receive a text from public mobile once the port is complete. Also, your account must be current and active with your old provider in order for it to be able to be ported and the delay time is that public mobile is dependant on when your old provider releases your phone number to them. Be patient, this is normal. In the meantime as others have mentioned, you can still use your old sim card with the provider you are leaving, it will work until the port is done and your account is closed with them automatically afterward.
08-20-2019 10:52 AM - edited 08-20-2019 10:52 AM
@Maninderminhas hi in the meantime you can use your old sim until port is complete until it stops working then you will know and do not cancel old plan until completion of port or you will probably lose your number good luck
08-20-2019 10:49 AM - edited 08-20-2019 10:49 AM
@Maninderminhas wrote:I am unable to receive calls but i can make calls can anyone please help me i just moved to pm yesterday. Thank u
@Maninderminhas You will only be able to receive call when your phone transfer from your previous provider completes 100%. In the meantime just use your previous providers sim card to make/receive calls until the sim card stops working. Once it stops working start using your Public Mobile card and everything should work.
Hope this helps.
08-20-2019 10:41 AM - edited 08-20-2019 10:42 AM
@Maninderminhas hi if it doesn't clear up soon it is probably a stuck port as suggested but depending who you ported your number from it can take a few days voip, land line even longer
08-20-2019 10:38 AM
Evn nt receiving texts also
@iliketotalk wrote:@Maninderminhas hi if you just ported a number its normal it can take a couple of days
if much longer contact a moderator here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
08-20-2019 10:23 AM - edited 08-20-2019 10:24 AM
08-20-2019 10:23 AM
Did you port your phone number? If so from which provider? It sounds like your port is stuck. You'll have to private message the moderator_team and ask for help
