12-11-2021 11:28 AM - edited 01-04-2022 04:59 AM
I switched from Fido 10 days ago and i still cannot receive phone call and did all trouble shooting as mentioned in the community.
12-11-2021 12:32 PM - edited 12-11-2021 12:33 PM
can you do a troubleshoot your device
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
APN Settings On An IPhone
click Here link,
or visit Here link,
APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do again Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
try to check update your device,
you can try to test your SIM card in another device to you know the issue from SIM card network or your device issue.
do you get a SMS message from your old carrier asking to confirm if you would like to Transfer your number. Your reply should be: YES.
maybe you stuck with Transferring your old Phone Number, or is not complete processing
Here’s how to contact Customer Support Agent by CS_Agent,
12-11-2021 12:24 PM - edited 12-11-2021 12:25 PM
You didn't mention, however we presume you can call out and send/receive text messages?
Try:
does it ring through the Fido service?
12-11-2021 11:52 AM
@Steptang wrote:I switched from Fido 10 days ago and i still cannot receive phone call and did all trouble shooting as mentioned in the community.
@Steptang was your Fido account ACTIVE when you ported?
If issues porting or transferring a number to Public Mobile, and it has been over the allotted time it usually takes to complete, submit a ticket here for help: https://widget.telus.tiia.ai/chatbot.html?botId=ZJkWuVb7Hp6EEcTIZKMZbvLwuDV&duid=1ml7MK2dvkmM37lFcEM...
OR, call the Telus Porting Phone number which I have private messaged you. Check your INBOX.
12-11-2021 11:48 AM
@Steptang....here's some reading that might guide you...
https://www.publicmobile.ca/en/on/get-help/articles/number-transfer-port-troubleshooting
12-11-2021 11:34 AM - edited 12-11-2021 11:38 AM
Did you port your phone number over to PM ? If you did and did you reply to the port request ? Try rebooting your phone.
