08-10-2019 07:36 PM - edited 01-05-2022 08:32 AM
The credit card I used to register was compromised and was being replaced when my monthly renewal came due. My account was suspended because of the lack on CC number and I am unable to reactivate it even though I have purchased a voucher with sufficient funds to meet the cost. I have tried the *611 route and using the Reactivate Current Plan button and the Make a Payment Button to add the voucher number. Soft ware seems to be going in circles and will not recognize my inputs. What the hell can i do now??
j
08-10-2019 08:04 PM
@GinYVR wrote:@jimideeWhen you add your voucher did you get a postive response that your voucher has been added? (eg there is a balance in your selfserve) The PIN is a 12 digit code.
As I understand it looks like the website just times out when they try to add voucher, so no really error message. I guess they should just keep trying from time to time while they wait for the moderator. It's probably the website issue.
But also phone won't let them add.
@jimidee what happens with 611 attempt?
08-10-2019 08:01 PM - edited 08-10-2019 08:02 PM
@jimideeWhen you add your voucher did you get a postive response that your voucher has been added? (eg there is a balance in your selfserve) The PIN is a 12 digit code. I would recommend making sure the voucher has been registered in the system first. As vouchers sometimes are not immediately valid if it is bought at a store.
08-10-2019 07:44 PM
@jimidee wrote:The credit card I used to register was compromised and was being replaced when my monthly renewal came due. My account was suspended because of the lack on CC number and I am unable to reactivate it even though I have purchased a voucher with sufficient funds to meet the cost. I have tried the *611 route and using the Reactivate Current Plan button and the Make a Payment Button to add the voucher number. Soft ware seems to be going in circles and will not recognize my inputs. What the hell can i do now??
j
@jimidee Adding a $1 or $5 to your account funds has been known to wakeup the reactivation process. Maybe worth a try.
08-10-2019 07:44 PM - edited 08-10-2019 08:01 PM
Can you contact moderators
In a meantime try Again logging in from time to time
Also try using incognito mode to try to add the voucher again
