03-24-2022 02:41 PM
Since 12:45 pm today, unable to make or receive calls. Anyone else? This is frustrating.
03-24-2022 03:19 PM
@Nic_Nic Thanks for updating and good to hear it was some temporary glitch and it's resolved itself.
03-24-2022
03:17 PM
04-03-2022
10:21 AM
Luddite
Update - seems like I'm FINALLY back online - must have been some system glitch, as it self-resolved. That was annoying, but thanks all!
[self healing by PM ........... Luddite]
03-24-2022 03:15 PM
03-24-2022 03:14 PM
turn off phone and take out sim card and put it back and turn on.
03-24-2022 02:47 PM
@Nic_Nic If today/overnight was your payment date, perhaps there was an issue with autopay failure (occasionally happens). Check your self serve account and it that is the case then try making your payment by selecting Payment tab.
Otherwise it could be network issue in your area/region?
Try rebooting the phone or toggling airplane mode on/off too.
03-24-2022 02:45 PM
Can your access your My Account. Does your plan show as active? You'll want to check this and see if there has been any issue with payment, etc to narrow down the issue and whether or not it is an error.
03-24-2022 02:44 PM - edited 03-24-2022 02:47 PM
Log in to your account to make sure it's Active and not Suspended. Make sure you have sufficient calling minutes remaining, if you're on a plan with limited time ...like the $15 plan (100 calling minutes)
edit...if so, consider upgrading to $25 or higher plan OR get 500 minute Canada wide calling add-on for $5.
