03-15-2023
06:11 PM
03-15-2023
06:52 PM
computergeek541
03-16-2023 08:53 AM
ifyou have tried different troubleshooting steps, I think it's time to open ticket with PM support
Please open ticket with PM support using Chatbot:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
03-16-2023 08:51 AM
Yes, my account is in good standing I tried it all and I’m not in the outage area so I don’t know what it is happening since yesterday
03-16-2023 08:28 AM
can you explain furhter what exacct the problem you have and what you tried?
BOTH incoming and outgoing calls have problem?
how about text?
how about data?
What exactly you tried?
rebooted the phone?
did you try to turn off the phone for 5 mins before turning it back on?
tried the sim card in a different phone?
tried the phone in a different area?
03-16-2023 08:26 AM
Having the same problem and I have done everything it says to do and it still drops the call.
03-15-2023 10:34 PM
take out the sim card and power down the phone and then put in the sim card power the power the phone and see that works
03-15-2023 08:23 PM
Try rebooting your phone to see if that helps.
Also for for outages in your area:
https://istheservicedowncanada.com/status/telus/map
If it still doesn’t work, contact a CS_Agent (Moderator) to check out the issue.
03-15-2023 06:47 PM
03-15-2023 06:12 PM - edited 03-15-2023 06:13 PM
