09-03-2021 12:06 AM - edited 01-06-2022 03:22 AM
I have used 16 of my 100 talking minutes but I can't make calls. It just tells me that I have used all my minutes but when I check my account I have lots of talking minutes left. What do I need to do to fix this issue?
09-03-2021 01:11 AM
@cobilie00 wrote:Same thing happened to me. I contacted them and they said the following:
“We are currently experiencing a network outage affecting HSPA and LTE service in your area. My Tech Team is now working to get the issue resolved as soon as possible.”
It’s been around 8 hours now and she still said they are working to get it resolved 😒
The above doesn't appear to be the issue being discussed in this messsage thread. When the member dialed a 1 before the area code, the call would work.
09-03-2021 01:05 AM
09-03-2021 12:59 AM
09-03-2021 12:29 AM
Oh that worked! Thanks for the help!
09-03-2021 12:29 AM
@hTideGnow wrote:What happen if you put a 1 in front of the 10 digits number, like 1-604-123-45677
Ironically, I would going to ask @AndrewH33 to double check if the numbers are being dialed correctly. Public Mobile has a bunch of strange and sometimes inaccurate error messages that could sometimes be heard if there's a mistake in the dialing.
09-03-2021 12:15 AM
09-03-2021 12:12 AM
yes, tried rebooting but still the same problem.
09-03-2021 12:11 AM
@AndrewH33 Try reboot your phone and see how it goes
