07-27-2020 09:07 PM - edited 01-05-2022 12:17 PM
I requested to reset my password twice and both times after getting the link in my mailbox, I proceed to create new password then I tried logging in with the new password and it fails. Please help, thank you.
07-27-2020 09:13 PM - edited 07-27-2020 09:20 PM
Hi @erotavlas ,
If the "Forgot your Password" is not working for you, contact the Moderator_Team via private message using this link. They should be able to fix you up.
07-27-2020 09:12 PM
@erotavlas contact the moderators and ask them for a temporary password to your self service account. There are 2 ways to contact the Moderator Team:
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
