Unable to edit APN
sharif72
I bought a new phone from Ali Express. It is P5 pro. OS is Android 12. when I am going to settings>Network & Internet>Mobile networks settings>Access Point names. It is showing Three default APNs. Koodo SP (by default), TELUS SP AND TELUS Services. I tried to add or edit APN. If I try toScreenshot_20220213-110139.pngScreenshot_20220213-110157.png tap on three dots on top right corner it shows only "reset to default" option. there is no Editing option. If I tap on any APN then every thing showing gray. unable to add or edit. I can not use any data service from public mobile.
I checked in the internet for this type of problem. For Huawei P5 phone some one suggested to go through
  1. "Enter 192.168.8.1 in the address bar of the phone's browser, and enter the login password of the web-based management page to log in."
I need urgent help to set my APN  and using data.
VIP_Tech
@Meow wrote:
@Dunkman wrote:
One trick is to have access to Freedom mobile or ROAM mobility SIM card and then able to edit APN Settings to Public mobile and save.
This is REAL neat trick! Did you actually try it @Dunkman ?
@Meow
I have not tried it myself.   But, it has worked for previous customers.
Dunkman
@sharif72
Some android phones do not have APN Settings for Public mobile and unable to edit due to manufacturer's settings. One trick is to have access to Freedom mobile or ROAM mobility SIM card and then able to edit APN Settings to Public mobile and save.  Then insert your PM SIM card and it should be working.
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Another option is to contact Customer service agent and I believe that CSA is able to send a file to update the APN Settings.
Meow
Is there something like unlocking developers' option on that phone?
Unless somebody here has exact phone with data working it might be tough to set it up, but I might be wrong.
You can always ask for agent's assitance:
Send a private message to the CSA by clicking https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Good luck and keep us posted if you resolve this issue!
