Unable to call 1-800 number
lindsayt93
Hello,
I am unable to call a 1-800 number to reach my credit card services.
I have a plan with unlimited Canada-wide call, text, etc.
When I call the 1-800 number an automated response says, "You do not have talk on this phone..."
Thanks,
Lindsay
10 REPLIES 10
Princess69
Afternoon Lindsay, were you able to locate a toll free # yet? Thank you Tammy
yg1
I am on a province-wide plan
PLUS I happen to have purchased a 200 minutes long distance bundle
Impossible to call 1-800-344-3370
I get the following message: "The number you have dialed is not available in your area at this time"
Someone please explain why or can someone fix this for me please?
N.B.  I can call the TD 1-800 number in this thread no problem...
What makes you phone different from the others?  Do you have different plans, addons, etc?
computer
iT'S WORKING ON THE OTHER 2 PUBLIC MOBILE PHONES HERE IN THE SAME HOUSE
mimmo
Where is the specific number located?  Some numbers are region locked ie a USA number can be called from Canada.
Message me the number and I can try see if it works for me.
will13am
Based on personal experience, I had the same issue with certain toll free numbers, not all.  I just use google voice to bypass the issue.  Over time, the problem kind of went away on its own.  Perhaps try adding + in front of the 1, see if that makes a difference.
sirvar
I would message @CS_Agent as it could be a problem with US toll free numbers or just that specific number.
@lindsayt93wrote:
Yes I can call any other number no problem.
Have you tried any other 1-800 number?
lindsayt93
NDesai
@lindsayt93 Are you able to call any other number within Canada? Is it just 1-800 numbers that you are hearing that error?
