Unable to activate
mingo123
Shows Error XXX when trying to complete activation on my account
2 REPLIES 2
HI @mingo123
I think you got this error at the end of the activation using the app?  are you activating esim or physical sim ?
if physical sim, check if the sim works.  If eSIM, do you get a Welcome email with a QR code for esim installation?
if you tried them all, then have support agent to check for you, please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
@mingo123  Are you using the app to activate . Not website . All activation need the app
