03-17-2024 09:44 AM
My daughter lost her phone, I can’t report it stolen as you need to be logged in. Can’t log in due 2 factor and we don’t have the phone. I had to create a separate community ID just get in here to ask. Hopefully this doesn’t just go into the void here. Please let me know how to get access
My Account
03-17-2024 07:50 PM
Thanks again for the help!!
03-17-2024 12:28 PM
All in a days “work” 😮💨
03-17-2024 11:46 AM
@HALIMACS Good job , I was also providing alternative way to get the job done . Seems like we both just trying to help
03-17-2024 11:41 AM
Sure @Handy1 , but isn’t that kinda going off-topic here & presuming the worst?
Although with recent happenings around here, understandable. 🫤
I was just suggesting a way they could get access immediately, instead of waiting for a customer support agent to get back to them
03-17-2024 10:13 AM
@HALIMACS I think OP should try anything that might work everything here is a crapshoot .never know from one day to the next what will work . Only thing that’s certain is PM will get your payment but that don’t mean you will always get your service
03-17-2024 09:51 AM
That could take hours, @Handy1 - especially with the CSA's likely dealing with complaints on the rewards debacle.
Shouldn't the OP try the option to get account access via e-mail first?
03-17-2024 09:48 AM
You should be able to receive the 2FA via email instead of text. When you first try to log in, click on Did not get code. Then it should offer the option for email instead.
03-17-2024 09:47 AM - edited 03-17-2024 09:48 AM
On the login page, tap the "didn't get the code?" and you should be presented with an option to receive the 2FA code via the e-mail address associated with the service?
Then, you can access the account, set the service to "lost/stolen", and re-acquire a new SIM card & device to re-associate the service to the new device.
03-17-2024 09:47 AM
@Rafaelhubbard Get support to help you with it
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send a private message To CS_Agents
