09-05-2025 10:44 AM
I ported to Public mobile on 4th Sept at 4.18 PM. I am still not able to access my network. kindly call me for support
thanks
09-05-2025 11:15 AM
@Bimalraj1 you don't need to cancel the service. Your issue is the Rogers sim. Disable the Rogers sim by toggle OFF "Turn on this line"
make sure the Public Mobile sim is enabled with "Turn on this line"
then Reset Network Settings and it should work, it should work for at least outgoing calls.
09-05-2025 11:02 AM
i did reset network, but its still not working
how do i cancel my connection
09-05-2025 10:53 AM
Phone is 16Pro max and it has 2 IMEI. one is showing public mobile and other showing ROgers under network provider
09-05-2025 10:49 AM
Yes, i did everything.
i opted for Esim
09-05-2025 10:49 AM
@Bimalraj1 is that a physical sim or eSIM?
You can try reboot your phone and check if the sim can connect to the network at all. If not, it is not an issue with porting but and issue with provision.
09-05-2025 10:47 AM
did you follow the suggested steps for successful porting of your number ? Did you reply YES to the port request within 90 mins. Is your Public Mobile sim in the cell now ?
09-05-2025 10:45 AM
hi @Bimalraj1 try reboot phone and reset network settings
if same, you need support agent to help
you can submit by direct message:
