11-30-2023
02:41 AM
11-30-2023
06:03 PM
computergeek541
I was able to select yes so my bell service is now canceled and I am unable to get text or calls or data with public mobile any help would be appreciated
11-30-2023 04:14 AM
Got it figured out thank you
11-30-2023 03:41 AM
Can you call 1-855-4PUBLIC from another phone …follow the prompts and see if your account is Active?
11-30-2023 03:24 AM
The esim should be active but I still have no calling my phone is not showing I have esim so therefore no messages no calling no data nothing but I got a message saying it was all active and whatnot but nothing is working no messages are coming in and no calls can be made nothing so I went and bought a Sim card and that doesn't work either
11-30-2023 03:16 AM
Is your esim still active or did you do a sim swap in self service with your physical sim? Did you delete your esim? Which sim is active?
11-30-2023 02:59 AM
I set up with esim but I also went and bought a physical Sim after esim wasn't working neither of them seem to be working they told me to reset network settings did that and still nothing
11-30-2023 02:56 AM
What type of SIM card do you choose, physical sim or e-sim, if e-sim, please buy new one to setup, if you are using physical SIM card, I think contacting CS_Agent would be only way
