08-15-2023 11:00 PM - last edited on 08-16-2023 10:19 AM by Dunkman
I have just subscribed for a plan and tried scanning the QR code provided twice, but the message I got was “unable to activate eSIM, try again or contact carrier”.
10-03-2023 08:15 PM
hi @Jhvicbc for me, is usually less than 2 hours
10-03-2023 08:10 PM
Thanks for this. What is the usual turnaround from CS?
08-16-2023 11:40 AM
Thank you everyone in the community for your kind assistance and tips. I have got a new eSIM from a CS agent and it is working now!
08-16-2023 01:11 AM
@Achan1 ,
In addition to all the great reference links and support provided above, the following information comes from Apple support:
If you can't set up an eSIM on your iPhone
Hope this helps.
08-15-2023 11:06 PM
Thank you. I’ve just sent a message via the link.
08-15-2023 11:05 PM
Yes it is - iPhone 13
08-15-2023 11:02 PM - edited 08-15-2023 11:03 PM
Dumb question, is your phone eSIM compatible? If you're still having problems, you can reach a CS agent below.
