New subscriber problem
Babselle
I don`t know what I did wrong but I tried to subscribe using an esim and suddenly got to a page that said my device is not esim compatible. I got a welcome from publicmobile.ca but I can't even get into my account.
12 REPLIES 12
Babselle
Ignore my last request for a new CS link. The one you gave me finally worked. Thanks again!
hi @Babselle
try this
ot go to CS agent profile here: @CS_Agent and click Send Message
Babselle
Hi JRod,
The link you gave me above failed to authenticate. it said the ticket is mismatched. Ccould I please have another link?
Babselle
Thank you very much JROd and @hTideGnow . I found on another webside a comment that lists all the S21 models that are esim compatible and the only model missing is the FE model. No reason why. I will try to get a regular sim card from the Telus store. Thank you both for your help.
Babselle
High Htide, I also thought my new phone was esim compatible but I got a reply from JRod which says that my phone is NOT esim compatible and he suggested I get a regular Sim card from amazon or a Telus store.  and send a request to a CS.
HI @JRod  you might be right
But @Babselle can you check your phone?  Check About to see if you have 2 IMEI and check SIM manager on your phone
JRod
@hTideGnow
The official Samsung webpage for that model states otherwise. Found on the bottom of the page in the fine print:
“*Use of eSIM/Hybrid SIM/Dual SIM on Galaxy devices has not been enabled in Canada.”
https://www.samsung.com/ca/smartphones/galaxy-s21-5g/galaxy-s21-fe-5g/
JRod
@Babselle
Based on a quick google search it sounds like eSIM might not be enabled on that model in Canada. Your best bet will be to purchase a physical SIM card off of Amazon (faster and cheaper) or picking up from a Local Telus Corporate store but call ahead before making the trip.
Then you can contact support and have them add the SIM to your account instead of eSIM.
Please click this link below to message customer service:
Keep an eye on your mailbox here as that is where your reply will come in (envelope icon on desktop, click your avatar icon in the corner and then click messages if on mobile).
@Babselle wrote:
My new phone is an S21 FE 5G. I did not see a QR code in the welcome email
HI @Babselle
no worries, it is eSIM compatible
But since no QR code there, please submit a ticket with CS agent and they will generate you one and send you
Babselle
HI @Babselle
you can try to install the eSIM yourself.  Check your Welcome email, is there a QR code there? if there is one, try to scan it and install the eSIM, then reboot the phone, Reset All networks on your phone and test the service
JRod
@Babselle
What phone do you have? On occasion that device incompatible error comes up on phones that are in fact eSIM compatible. If your phone is in fact compatible you can manually add it using the QR code that was sent in the welcome email.
If your device isn’t eSIM compatible you can purchase a physical SIM card and get support to add it to your account as the account will not be fully setup until activation is complete.
