US travel & Roaming
Mutey
I am traveling to the US soon. I have lot of data on my plan. Can I use this data while in the US or do I need to activate the US roaming to be able to use my line in the US?
@Mutey
Only if you have the Canada/USA plan that works in both countries but if you only have the Canada plan…yes you need to purchase a USA Roaming data plan.
eddieO
@Mutey below would be the roaming options you could choose from:
Under Bundles:
US Roaming - Talk, Text and 3GB Data (15 days only)- $30 (25 Reward points)
US Roaming - Talk and Text (15 days only) - $15 (10 Reward points)
Under data only:
US Roaming - 250 MB Data (15 days) - $10.00 (5 Reward points)
US Roaming - 1GB Data (15 days) - $20.00 (15 Reward points)
US Roaming - 3GB Data (15 days) - $25.00 (20 Reward points)
Rastin
Roaming will need to be on. But you need a plan that's covers both us and canada. If you don't you can buy an add on for us or change your plan to one that has both us and canada coverage
