US travel add-on
andreabeaton
Hi,
Can you add the same US travel add-on the same day that it expires? From my last experience, it seems it required a 24 hr break.
Thanks,
Andrea
smp99
Don't get me wrong, I love PM and not going anywhere - but this makes the company look so amateurish.
hairbag1
@andreabeaton
wait until the 360 hours has expired...plus 24 hours before re-buying the same add-on.
Different add-on is ok...just not the same.
dust2dust
Not while the add-on is still shown in your add-on list. When it goes to 0/15 then it should be about 12 hours after that.
You can always ask support to buy them whenever.
@andreabeaton
yes, it needs to wait 24 hours (but some said 12 hours)
You can buy  a different one , then you don't have to wait
Or you can open ticket with PM support and have them to re-buy it for you without the wait
