US talk time
08-17-2019 02:53 PM - edited 01-05-2022 06:28 AM
08-17-2019 03:06 PM
08-17-2019 03:04 PM
@Slug27 Did you perhaps mean to mark @iliketotalk post as solved and inadvertently marked you own?
08-17-2019 03:02 PM
@Slug27 hi just a heads up you dont give yoursef the solution it is usually for the person that gave you the solution
08-17-2019 03:01 PM
@Slug27 wrote:I assumed it charged me every month. I’ll try the add on again and see what happens. Thanks.
Add-ons don't expire they stay with your account until used up, except for US roaming which are good for 10 days only. Only your plan will be renewed and charged every 30 days.
08-17-2019 02:59 PM
@Slug27 no problem your welcome
08-17-2019 02:59 PM
@Slug27 wrote:I have the 200 minute US talk add on.
The minutes haven’t been resetting every 30 days and now I only have 4 minutes left.
Just purchase it again.
Remember purchasing Add-ons is a TWO step process. Once you add the funds, then you need to make the actual purchase. Detailed instruction: https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/m-p/198974#M22...
08-17-2019 02:58 PM
08-17-2019 02:56 PM - edited 08-17-2019 02:58 PM
@Slug27 if you have an add on for that it doesnt reset every 30 days you only paid for it once it is there until used up
