06-08-2019 11:35 AM - edited 01-05-2022 05:17 AM
Hi
I just purchased US roaming talk text add-on and US roaming 500mb data add on.
The transaction went through.
The roaming data add-on is correctly shown in the my data and add-ons secion of the self-serve overview page. However the talk text add-on is missing and I cannot find if the talk text add-on is active anywhere (such as add-on usage page).
I'm wondering if the vocie and text will work or somethign went wrong.
Thank you
Donghun
06-08-2019 12:38 PM
You are probably fine with what you describe. You bought two separate add ons (Unlimited Talk and International Text $15 and 500MB Data for $15). The website is finicky at times.
Make sure to turn on roaming when you get to the USA.
06-08-2019 12:11 PM
Hi guys
I purchased a us roaming talk and text bundle and a roaming 500mb data.
It is strange that unlimited us talk (instead of talk and text) showed up after a while in the current add-ons section if I press purchase Add-ons button in the overview page.
It is still missing in the my data and add-ons section.
The transaction history is correct.
$30 was charged for 500mb data and talk/text bundle.
It is probabily OK but I'm not quite sure and confused.
Thank you!
06-08-2019 11:47 AM
I just checked PM website. There is only a US text talk and data bundle with 250 mb. You probably purchased wrong one.
If if you want to change you will need to contact moderator. Expect at least 1-2 day wait.
06-08-2019 11:47 AM
Can you look at your payment history\(mb post a screen shot) , do the line items show both addons? do you have any available funds left? how much were was your cc charged?
I'm thinking maybe you only were charged for one addon?
06-08-2019 11:43 AM
@malonee72- Did you performs the second step for each add-on. Remember that purchasing add-ons is a 2 step procedure. First you add the money for the add on, then you actually buy it. Check your account balanc to see if there are still funds there. Also, check your bank info to see if you were charged for both add-ons. You might have done step 1 & 2, but for only one of the add-ons.
06-08-2019 11:41 AM
From my past experience, you should see the other text and talk US options in your add on section. If I remember correctly...,,
Did you just just purchase the 500 mb data alone? How much was taken from your account?
