11-03-2024 07:12 AM
11-03-2024 07:42 AM - edited 11-03-2024 07:44 AM
@markzzz24 no need to purchase anything extra your plan has roaming built into it . And you can use to call to and from each country while in either country call text and data
When in the U.S. you need to turn data roaming turned on in phone settings ? Also set phone to 4G/LTE not 5G and make sure your connecting to T mobile AT&T or Verizon
also check the PM
voLTE white list if your phone not in the list you won’t be able to make voice calls in the U.S.
VoLTE white list
