US roaming addon doesn't work.
gnordoff
I'm home now back in Canada. I drove from BC through the top part of the US back to Ontario. My phone, S10+ plan and addon would not work unless I re-booted the phone everytime I needed to use it. The service was off most of my trip accross the US. I want a refund. It's not the phone but the addon service.
1 ACCEPTED SOLUTION
Accepted Solutions
@gnordoff  Not sure why you need to reboot every time.
But you can open a ticket with PM Support and discuss with them about your experience.  Depends on the usage, they will work out some kind of compensation or a full refund.  So, open ticket and check with them:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
Meow
PM US add-on is Not reliable anymore due to US shutting down 3G network.
gnordoff
The reason I had to re-boot the phone everytime I wanted to use it, is because T-Mobile in the US would not transfer my IMEI number from one tower to the next.
