10-07-2017 05:44 PM - edited 01-05-2022 03:23 AM
I have an active CAN US long distance 200 min calling plan which I have previously used 18 minutes from. It is my understanding that they do not expire but now when I try to make a call it tells me I do not have an add on even though my account is showing I have an active add on.
May I have some help please? I have some business calls I need to make!
Service
11-10-2017 04:37 PM
@simonguillot in that case, you will need to click here to send a private message to the @moderator_team for assistance. They are Public Mobile support employees who can help with your issue.
In your message please include:
- PM account email address
- PM phone number
- Detailed explanation
Note: Community Moderators are available from Mon-Thursday 9am to 9pm, and Friday, Saturday, and Sunday from 9am to 7:30pm [All times in Toronto/Montreal time zone]. You can message them at any time, and they will respond as soon as possible within those working hours. More information about the community moderators.
11-10-2017 04:29 PM
it tells me the call cannot be completed because i do not have a long distance add on
bu
I do !!
11-10-2017 03:02 PM
@simonguillot what happens when you try to dial a long distance number? Are you dialing it with the "1" at the beginning of the number? Do you hear a message that long distance charges may apply? If so, does the call not connect right after?
11-09-2017 09:21 PM
i too have this issue
i have the add on but unable to do long distance
since when this is this way ?
am i paying for something i am not using ?
10-08-2017 12:36 PM
You were definitely spot on, except I was only silent because of a busy day lol. Thanks for your replies and help guys.
10-08-2017 12:13 PM
10-08-2017 11:26 AM
@Michael77, it has been my experience that if the post goes quiet the OP realizes that it was their error or misunderstanding of the plan. I could be wrong but that is what I have noticed.
10-08-2017 08:54 AM
10-07-2017 07:17 PM
@ShawnC13, good catch.
10-07-2017 06:01 PM
@84DerekNg, just a quick question are you currently in the US trying to make a call? That long distance plan is only for calls originating in Canada. If you have travelled to the US you won't have service unless you have Purchased a US add on. If you are in Canada trying to call the US there are certain area codes that can not be called . Here is a list https://productioncommunity.publicmobile.ca/t5/Announcements/Which-U-S-area-codes-are-not-supported-...
10-07-2017 05:46 PM
It sounds like you hit a bit of a snag with the self-serve portal. You'll need the help of a moderator to get your account sorted out and get this add-on manually added back.
Send a private message to @CS_Agent, include your following info:
- account number
- phone number
- a brief description of what has happened
…and they will be able to look into it for you.
Click the link for an explanation on how to private message the moderators: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Moder...
*** I’m here to help but I’m not a PM Moderator, so please don’t private message me with any of your account information. ***
