03-01-2026
03:17 PM
03-01-2026
04:23 PM
computergeek541
Does anything change? Phone number, settings etc...
edited by computergeek541: changed category (discussion isn't related to Community)
03-01-2026 03:53 PM
for talk while in US, you MUST have a VoLTE recognized cellphone...otherwise talk won't work. Data and messaging will be ok...just be sure to enable roaming. Here's some info about VoLTE with a device checker at the bottom of the article.
03-01-2026 03:44 PM
hi @soupysr
remember to turn on Roaming data
and when you are in US , make sure the phone connects to T-Mobile or AT&T or Verizon. if it does not connect to either one , manually connect to it
03-01-2026 03:29 PM
@soupysr No nothing changes , but when your in the U.S. and will need to enable data roaming in phone settings to use your data is all
