US add on talk, text,data
DaveMc
Do I need to turn on data roaming in settings for the US talk,text,data to work?
DennyCrane
Yes, for data roaming to work you need it on. I recommend PM customers always leave it on as there is no chance of surprised overages (i.e. if you don't purchase a prepaid add-on it won't work anyway).
HALIMACS
Yes @DaveMc
HI @DaveMc   for  US talk,text,data to work, you need to turn on data roaming in the settings, that is to make sure data part works
@DaveMc   if it is just for Talk and text, you can leave the data roaming off on your device
However, you got the roaming Talk/Text/Data bundle? If so, you need to enable the data roaming on  your device for roaming data to work
