US Talk and text/data using points
Mel8557
For the add-on US talk and text/ data for 15 days using my points, can I call Canada from the US or is it just calls within the US?
2 REPLIES 2
Socrates8567
Yes, you can. If you purchase a U.S. Roaming Add-on (or have a Canada-U.S. plan), you can make calls from the U.S. back to Canada, as well as to numbers within the United States.
VoLTE is Required: Since U.S. carriers (AT&T and T-Mobile) have shut down their 3G networks, your phone must support VoLTE (Voice over LTE) to make voice calls. If your phone is older, you might find that only data and texting work.
The IMEI Check: Visit the Public Mobile VoLTE help page and enter your device's IMEI (dial *#06# to find it). This is the only way to confirm if Public Mobile has "whitelisted" your specific model for VoLTE roaming.
I suggest you check your phone first before purchasing a US addon or using your points to purchase it.
hi @Mel8557 yes, with the talk text and data US roaming, you can call back Canada while in US as well
