US Roaming
gianphuy
Hi gang,
My father is currently in the US, I logged into his account and purchased the US Talk 10 day 7 days ago and thing were working fine, until he realized he needed text and was staying a little longer, so I went into his account yesterday and purchased the Talk & Text (10 Day), then when we receive a call from him in the evening, our calls get dropped after 20-30 seconds, we call him back and it drops after 20-30 seconds. It's hard to hold a conversation having to re-dial or him calling us back. Just trying to get some help for the old man who's trying to enjoy the vacay and call home or his friends in the US.
Also, in the Add On Tab it shows this:
US Talk (10 Day)
US Talk (10 Day)
US Text (10 Day)
Could purchasing the US Talk & Text have caused this issue?
Please help.
Thx!!!
14 REPLIES 14
@gianphuy wrote:
Is this for sure? Seeing that I have already purchased it and it's been applied, do we just wait for the initial pass to end now?
Sorry, don't know. You'll be the first to discover if that succeeds.
For a real chat he could try an application like that from fongo.com. It provides free calling across Canada from wherever you are connected to wifi, or on cellular data.
gianphuy
Thanks for the response @Luddite, we are trying to have quick conversations with him, like trying to spew whatever we can in 30-40 seconds, and just texting.
System won't accept renewing a roaming add-on early. You can only "renew" the day after expiry. So, you have likely discovered a new bug by adding text which would be allowed but more calling which is not.
Definitely you need moderator assistance, BUT given their backlog it may be a day, or two, before you have a response.
There may be some workarounds if you need to stay in touch but would depend on you all being comfortable using data. Let us know.
gianphuy
When a pass ends, you can buy the US add on again. Unfortunately you cannot stack the add ons. So you would have to wait for the first pass to end, before adding another one of the same type.
gianphuy
That's what I'm figuring as well, but because his initial talk pass was ending, I bought the Talk & Text Pass so that he wouldn't have to worry about losing his Talk when the initial pass ended.
Usually you cannot stack us roaming add ons of the same type. As you had US talk before, and then added US Talk and text, it could have caused an issue with calls since there is now technically two US calling add ons now. You should have only added US Text. Perhaps one of the orcales or mods could confirm that this could be an issue
neatooo
buying an addon is a two step process. you buy it first, which gets money from your card. then you buy it again using the loaded money. Did you do that?
Usually reboots help. Try that
** I am not a Mod, please do not include any private info in a private message to me.**
gianphuy
I believe he's tried that as well, but the issue here is that it was working fine when I initially purchased the 10 Day Talk pass, but purchasing the 10 day Talk&Text pass seemed to have started the call drop issue.
neatooo
have you tried selecting the US network there manually?
gianphuy
He's tried that, still getting the dropped calls.
neatooo
please reboot phone
