06-16-2017 01:12 PM - edited 01-04-2022 01:53 PM
I am thinking of adding the US Roaming for a trip coming on. If I add it now, will it start right away?
06-16-2017 01:16 PM
"If you need U.S. roaming, long distance or extra data added to your plan choose of one the Add-Ons. Just a heads up, you’ll need a plan before you can add the Add-On, and all Add-Ons come into effect immediately after purchase."
06-16-2017 01:15 PM
Hi @ashleypham!
Yes. The US roaming add-on will become active from the moment you buy it for 10 days.
06-16-2017
01:15 PM
06-16-2017
01:37 PM
Luddite
@ashleypham, yes the addons are active as soon as you purchase them. When you do purchase the addon it is a two step process first you select your addon and have the payment taken from your credit card. That payment actually then goes to your Available Funds. You will then need to go in and re-select the addon you want and then the money will be taken from the Available Funds to pay for this addon.
