US Roaming add on
Delliott
I have a $20 talk/text/data bundle add on and was trying to add it for another 10 days and it isn't there anymore. Did the add on's change?
Delliott
Thank you!
@Delliott  It is also possible an issue with the site.  Many people report unable to logon to Self-Serve.
HALIMACS
@Delliott
If you need the add-on sooner than 24 hours, you might try requesting the moderators intervene.
To contact a moderator, there are 2 methods:
  1. Use the ticketing system for a faster response time. Click here and type moderator assistance, then select account-related issue, then select you need a human now.  Follow the prompts to submit a ticket,  or,
  2. Send a private message to the moderator by clicking here  You’ll need to be logged into your Community account for the link to work.
Triguy
  • If you want to purchase two of the same U.S. Roaming Add-Ons, you will have to wait for the first 10-day period to expire before buying the second, or you can contact a Moderator.
Here’s when and how to contact the Moderator Team:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
hairbag1
@Delliott...
Wait until 24 hours after the first add-on expired.
EDIT...you can add one of the other 10 Day US Roaming options....just not the one you have until it expires.
