US Roaming - Talk Text 250 Data (10-day): unlimited calls to US nos + canadian nos?
deepro
Hello,
I want to buy the US Roaming - Talk Text 250 Data (10-day) add on. I just want to confirm whether it gives unlimited calls and texts to US numbers as well as Canadian numbers. If not then what would be the charge of calling to a US number/Canadian no?
surreyboz
@deepro wrote:
Hello,
There are no Pay per use Charges or overages with Public Mobile regardless of how much available balance you have. If something is not included in your Plan or any Add ons you have purchased it simply just wouldn't work.
deepro
Thank both of you for the answer and the clarification!
cavemantoronto
@deepro wrote:
Hello,
It does like Dunkman says but know that that it is only good for using in U.S. Leftover minutes, texts, data can't be used when you are in Canada.
Dunkman
@deepro
Yes, the US roaming will cover unlimted texts, calls to Canadian and US numbers.
Here is the knowledge article on add ons:
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Plans-amp-Add-Ons/ta-p/250167
